K1200S Clutch Issues when pushing the bike
    I think I posted this is the previous site.
    My K1200S's clutch lever goes down when pushing the bike.
    Meaning that the lever gets closer to the handlebar on its own and you cannot actuate the clutch.
    That gave me a few scares, of not being able to clutch down and actuate the clutch. This can be done by pumping the clutch a few times.
    I did purge at least three times.
    Left the clutch lever pressed for over a week, not just overnight.
    Bought the Oberon slave cylinder.
    Replaced the clutch master cylinder. Used the one on my K12R.
    The issue is still there.
    Any ideas?
    Thank you!
      Right... when everything else has been corrected, go back to the beginning, right?
      I found two other clutch packs, I made a mix up a while back ago. How do know which one is newer? by the total thickness (height) of the clutch pack?
