Got on the bike (2010 K1300GT, 30,000 miles) to go home and it ran poorly. Would barely hold idle. Dies if I ease on the throttle but will rev (roughly) if I yank it. Replaced all four coils (at least one was suspect), four very sooty spark plugs and sooty O2 sensor, didn't help anyone but the vendor.
I used the GS-911 to data log, see attached pdf. O2 sensor voltage about 0.9, cat is glowing when I look in the pipe, rev it to see the black smoke. Rich, for sure, but why?
I need to ask more questions before the dealer gets it. One, is the fuel system non-return? If so I assume the fuel pump is controlled directly by the BMS-KP unit. How is fuel pressure monitored? I get a fuel pressure reading from the GS-911 of about 2878. (units unknown). If 2878 millibars that's about 42 psi which sounds about right. Using the live data function, the throttle position sensor seems to be working. I trust the new 02 sensor. The ambient air temp is about 30 degrees lower than actual due to a resistor (forget the brand) on the intake air temp sensor when I tried to cure hot stalling which still happens.
Anyone got a suggestion?
