R1200GSA, hesitation with hard acceleration
    Like the title says, I find some hesitation during accelarating. It seems to go then there is pause and and then go again...
    The only thing I can think of is the plugs. I changed them to the NGK platinum a while back as the OEM seems to get worn quickly.
    Any ideas?
    With recent fill up? Check the air filter? If you can get your hands on a 911, it could also check for a faulty coil.
      Or one of the spark plug coil is bad.
        Lol! Wish I wooda said that!πŸ˜πŸ˜„
          oups, didn't see that.
            Yep! that could be it. A coil. Gonna take it in. No fault codes yet.
              Maybe it’s searching for its two missing cylinders
                Good one Karl.
                  Eric had a bad coil once
                  My dealer mentioned a connection on top of the fuel tank gets water in in and corrodes.
                    Good points. I will bring it up with the dealer
                      That problem was corrected in the wc bikes and I’m pretty sure before that by a year or two.
                        Didn't see what model he had.
