Favorite Menu Item on Info Display?
    When scrolling thru the Menu on my K1300S I like all the nice info (time, temp, fuel, miles left, ect.) but typically leave it on the Tire Pressure indication. I just feel better instantly knowing what the Pressure is even though it will warn me if if it begins to drop. What info do you typically leave there?
    I leave mine on air temp.
    If I want to check any other value I bump the wonder wheel to the left and see 16 values in one screen.
    You need a BMW Navigator for this and a wonder wheel.
      I leave it on range on my XR. The GSA, my bladder will let me know.
        Same here, Range is the setting I use the most. When we're off road I'll use the GPS to display engine temp and tire pressures. It's reassuring to know at a glance that all is well.
        p.s. I have tried, and still try, to get used to the TFT display where all critical data except the tach is shown. Love seeing all that info on one screen in the TFT but decades of analog info have me more comfortable with the tach / speedometer combo.
          Clock mostly until gas gets low, then it's range. If I'm wondering about the temperature I probably don't want to see it anyway.
              Who has time to look at things like this?
